ABS stress-strain data
Hello all!
I write this post because I've been looking for an answer on the internet for almost two weeks and I've not been able to find anything. The info I'm looking for is the stress-strain data of the plastic ABS. I need this information in order to make a non-linear analysis by ABAQUS.
I'd be also interested in the same data about an aluminium/steel but I should be seeking wrong because I just find the curve, but I need the tabulated data.
Thanks in advance!
Thanks in advance!
RE: ABS stress-strain data
Rick Fischer
Principal Engineer
Argonne National Laboratory
It is a mixture of three polymers, the ratio of these is varied extensively to get different properties (e.g. High gloss, high heat, toughness, etc)
There must be a gazillion different grades of it made by a gazillion manufacturers. Just a thought...
H
www.tynevalleyplastics.co.uk
It's ok to soar like an eagle, but weasels don't get sucked into jet engines.
I'm not a material specialist so the ABS for me is a plastic hahaha.
I know there is a wide variety of ABS with different properties, but I meant a generic ABS plastic, I don't need the data of a specific one.
Chris DeArmitt PhD
President - Phantom Plastics LLC
Consulting, ideas and training on plastic materials
www.phantomplastics.com
