How to Batch Convert 2D UG NX8/9 Drawings to .cgm
RE: How to Batch Convert 2D UG NX8/9 Drawings to .cgm
Since the OP in the other thread had the same problem, "a general error about how that program has stopped working", I'd guess you have not correctly added the path to the UGII folder into the "path" environment variable...
www.nxjournaling.com
Franks instructions were to place the NXDrawingsToCGM.exe file into the {NX install folder}\UGII\managed folder and add the path to the UGII folder to the PATH environment variable. Go to control panel and find the environment variables, look for the one named PATH, choose it and press the Edit button. Do NOT delete any contents of this variable, append the location to the UGII folder by placing the cursor at the end of the contents of this variable then add a semicolon (;) and the path to your UGII folder (C:\Program Files\Siemens\NX 9.0\UGII\). The semicolon is a delimiter to separate the various individual path values. Save your changes.
