NX 8.5 Pattern Curve
I am trying to use "Pattern Curve" to instance in a sketch. On sheet one of the attachment I have one menu and on sheet two, another menu of the same command, however with different options. The one I need is "Create Pitch Expressions" so I do not have many constraints. The problem is I cannot get this menu on the other model. Is there a way to customize or adjust preferences to get this function? This is a quark because I have opened both of these sketches in the same version.
RE: NX 8.5 Pattern Curve
www.nxjournaling.com
