IPX6 Testing
IPX6 Testing
I have a question about the IEC 60034-5 code for water ingress testing. It says that you need a water pressure of 100 kPa at the nozzle, which is about atmospheric pressure. It also wants a flow rate of 100 l/min. If I want to do this testing on my own, how am I supposed to regulate pressure and flow at the same time?
Thanks for any help you can give.
RE: IPX6 Testing
you must get smarter than the software you're using.
