URGENT-Restart not working
I am receiving the following error when I try to restart a job that failed due to a license update over the holidays. This is a problem I have never had so I am unsure how to format the restart input file.
***ERROR: NEW STEP DATA IS MISSING FROM THE INPUT FILE WHEN *RESTART OPTION IS
USED. NEW STEP DATA MUST BE DEFINED.
My restart input file contains only the text below.
*Restart, read, step=1
I need to input the step data to ensure that the analysis continues exactly as it did prior. I have listed the original step information below.
** STEP: Step-1
*Step, name=Step-1, nlgeom=YES
*Dynamic, Explicit
, 7.
*Bulk Viscosity
0.06, 1.2
** Mass Scaling: Semi-Automatic
** Whole Model
*Fixed Mass Scaling, dt=5e-06, type=below min
Thank you for your help.
I have also attached the original input file for reference. (I have removed the model data to save size)
** STEP: Step-1
*Dynamic, Explicit
, 7.
*Bulk Viscosity
0.06, 1.2
** Whole Model
RE: URGENT-Restart not working
The file now fails on the packager however with the error "Abaqus/Explicit has encountered an internal error". Any ideas?
