Import Assembly into Teamcenter clone file lists scenario with jt files
I'm trying to import a native NX9 assembly into Teamcenter 9 but the clone file created lists many scenario lines with _jt parts.
I would like to just delete it but I don't see how to do it in NX?
Can I just remove the lines from the clone file?
Assembly Cloning Log File
&LOG Operation_Type: IMPORT_OPERATION
&LOG Default_Cloning_Action: OVERWRITE
&LOG Default_Naming_Technique: AUTO_GENERATE
&LOG Default_Container: "awparker:Newstuff:LBNE-Absorber"
&LOG Default_Directory: ""
&LOG Default_Part_Type: Fnl4_DesignItem
&LOG Default_Part_Name: ""
&LOG Default_Part_Description: ""
&LOG Default_Copy_Associated_Files: Yes
&LOG Default_Non_Master_Copy: specification Yes
&LOG Default_Non_Master_Copy: manifestation Yes
&LOG Default_Non_Master_Copy: altrep Yes
&LOG Default_Non_Master_Copy: scenario Yes
&LOG Default_Non_Master_Copy: simulation Yes
&LOG Default_Non_Master_Copy: cae_motion Yes
&LOG Default_Non_Master_Copy: cae_solution Yes
&LOG Default_Non_Master_Copy: cae_mesh Yes
&LOG Default_Non_Master_Copy: cae_geometry Yes
&LOG Default_Associated_Files_Directory: ""
&LOG Default_Validation_Mode: OFF
&LOG
&LOG
&LOG Part: D:\20141021_VladimirSidorovNativeNX\LBNEabsorber\Absorberassembly\1screw3_MODEL_SOLIDS_inst10_jt.prt
&LOG Cloning_Action: DEFAULT_DISP Naming_Technique: DEFAULT_NAMING Clone_Name: @DB/F10029316/-/scenario/1screw3_MODEL_SOLIDS_inst10_jt
&LOG Container: ""
&LOG Part_Type: ""
&LOG Part_Name: ""
&LOG Part_Description: ""
&LOG Associated_Files_Directory: ""
&LOG
&LOG Part: D:\20141021_VladimirSidorovNativeNX\LBNEabsorber\Absorberassembly\1screw3_MODEL_SOLIDS_inst11_jt.prt
&LOG Cloning_Action: DEFAULT_DISP Naming_Technique: DEFAULT_NAMING Clone_Name: @DB/F10029316/-/scenario/1screw3_MODEL_SOLIDS_inst11_jt
&LOG Container: ""
&LOG Part_Type: ""
&LOG Part_Name: ""
&LOG
