Help/ advice needed; getting absolute coordinates
Hi
I am working on a macro for extracting the absolute coordingates for the points making up a polyline, and have been tinkering around with the existing functions at http://www.eng-tips.com/faqs.cfm?fid=1824. I am using the function for getting relative coordinates, and I have integrated the first code under the link so that I can define variables as the custom datatype iPct, so that part works. The problem comes when I try to get the coordintes using the measurable function. The macro stops at the highlighted point and gives the error message: "Compile error: ByRef argument type mismatch". I think there is something with the datatype that it doesn't like.
Has anyone else been able use these macros to get absolute coordinates and what kind of datatype did you use? Did you have to change the code?
I would greatly appreciate any help.
CODE --> CATVBA
'coordinate extraction process
Dim TheSPAWorkbench As Workbench
Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench") ' set TheSPAWorkbench
Dim MeasurePoint, MeasureLength As reference
Dim oRad As Length
For i = 1 To polyline1NrOfElements 'iterate through all poinst of polyline
myPolyline.GetElement i, activePoint, oRad
Set MeasureLength = TheSPAWorkbench.GetMeasurable(myPolyline)
myPolylineLength = MeasureLength.Length
LCS axisSystem1, (activePoint)
If oRad Is Nothing Then RadiusAtPoint = False Else: RadiusAtPoint = True ' check if Radius at point
'add point index
mytable.SetCellString 2 + i, 1, catPointIndex & i
xPoint = Round(Diff.X, 1) 'check decimals
If xPoint = 0 Then 'avoid division with zero
mytable.SetCellString 2 + i, 2, "0,0" 'add "0,0"
ElseIf Int(xPoint) / xPoint = 1 Then 'check if integer
mytable.SetCellString 2 + i, 2, xPoint & ",0" 'add ",0"
Else
mytable.SetCellString 2 + i, 2, Round(Diff.X, 1) 'else, use 1 decimal
End If
yPoint = Round(Diff.Y, 1) 'same procedure for y and z
If yPoint = 0 Then
mytable.SetCellString 2 + i, 3, "0,0"
ElseIf Int(yPoint) / yPoint = 1 Then
mytable.SetCellString 2 + i, 3, yPoint & ",0"
Else
mytable.SetCellString 2 + i, 3, Round(Diff.Y, 1)
End If
zPoint = Round(Diff.Z, 1)
If zPoint = 0 Then
mytable.SetCellString 2 + i, 4, "0,0"
ElseIf Int(zPoint) / zPoint = 1 Then
mytable.SetCellString 2 + i, 4, zPoint & ",0"
Else
mytable.SetCellString 2 + i, 4, Round(Diff.Z, 1)
End If
If RadiusAtPoint Then
radPoint = Round(oRad.Value, 1) 'same method as above
If radPoint = 0 Then
mytable.SetCellString 2 + i, 5, ""
ElseIf Int(radPoint) / radPoint = 1 Then
mytable.SetCellString 2 + i, 5, radPoint & ",0"
Else
mytable.SetCellString 2 + i, 5, Round(oRad.Value, 1)
End If
End If
End if
