[APDL] Bending moment diagram
Hello to all
I am having troubles with ploting digrams of bending moments in Ansys APDL
I used this command for beam 188 elements:
etable,moz1,smisc,3
etable,moz2,smisc,16
plls,moz1,moz2,-1,1
It works fine, however, later I need to change orientation of beam's cross-section. I use command:
Lsel,,,,1 $ latt,,,,,4
where 4 is a Keypoint.
Do you know to solve it?
etable,moz1,smisc,3
plls,moz1,moz2,-1,1
RE: [APDL] Bending moment diagram
To solve what? You said plotting the bending moment was working?
The LATT command needs to be followed by a remesh and of course by a new solve. You are changing the physics of your problem if you change the orientation of your beams...
/petb
