URGENT - coating steel structure in marine enviroment
We need to protect a steel structure of approx 5m high that takes a load of 22T and is in a marine enviroment.
Hot dip galvanising seems to be the classic solution, but considering the size of the structure this causes some problems with the sub-contactors our client has approved(!!)
Is there a paint based process that can be used w/o baking that can produce a similiar level of protection.
Many thanks for your help
Hugh
Hugh
RE: URGENT - coating steel structure in marine enviroment
The key is to have the steel fabricator apply the paint system in the shop. The fabricators usually have a favorite paint supplier to work with. As long as this supplier is a reputable company (who also stands behind the application, so the fabricator and paint maker don't point fingers if it fails), the likely system would be an organic zinc primer (4 - 5 mils DFT) with a high-build urethane topcoat (4 - 5 mils DFT) (epoxies are good too but tend to chalk over time).
Some touch up after erection will improve the chances of a 15 year life, which is reasonable expectation for this system.
It is actually a very high zinc content in the dry film paint, it actually looks like Galvanizing.
