how to define maximum range depth in shop documentation or in NC out File
how to define maximum range depth in shop documentation or in NC out File.
RE: how to define maximum range depth in shop documentation or in NC out File
I assume you are looking for the lowest Z value.
In short, you can do this in the post.
In shop docs, it is possible for a 3 axis machine if you list and examine the tool path, but not for multi-axis, because you need to postprocess to get the actual Z values.
This has been discussed many times over the years - I would start be searching the archives of the NX CAM forum at http://community.plm.automation.siemens.com/t5/NX-...
Mark Rief
NX CAM Customer Success
Siemens PLM Software
