Can't make diameter dimension go across the circle
I can't find the place to change the diameter dimension from a small arrow on the outside of a circle to one which also has a line going across to the other side.
Frank Reid
Reid Engineering Services of Utah
RE: Can't make diameter dimension go across the circle
Frank Reid
