Deformable constraints
Hi All,
I have a small problem which im sure there will probably be an easy solution.
I have created an assembly with two parts, i have then assembly cut these parts. I now want to add this sub assembly to multiple assemblies but in each assembly i want the distance between the two parts to be different, how would i go about doing this?
Thanks in Advance
James
Thanks in Advance
James
RE: Deformable constraints
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
"My english is bad ? That's why i'am french."
Thanks for the responses, i figured out a way around it, instead of using a distance constraint i made sure that they were inline with each other (constrained the holes in the guide) and then i used 'override position' and i was able to change the distance without affecting the original model.
James
