Compressor - Regulator - Plenum - Exit. Regulator not providing correct plenum pressure
I have a workbench test set up which consists of a compressor, followed by a 6bar supply line, followed by a regulator (for bringing the pressure down to 2bar) followed by a plenum chamber that leads to a slot that vents to atmospheric. The slot is approximately the same area as the supply line pipe. There is a pressure tapping in the plenum chamber to measure stagnation conditions. I want a plenum stagnation pressure of 2bar. The flow rate at this pressure is 0.1294kg/s which converts to 3240 l/min given the density of the air at this point. The regulator I have has flow characteristic curves for an input pressure of 7bar but show an output of 2bar is easily achievable at this flow rate. I understand the input pressure is 6bar in my case however, given the high max flow rate shown by the characteristic curve I believe I should still be able to achieve 2bar output with a 6bar input. The problem: The maximum plenum pressure I am able to achieve is about 1.3bar. If I try and increase the pressure past this nothing happens, it is as if the flow is choked. Given that the regulator should be able to produce 2bar output with a 6bar input at the design flow rate, why would my regulator be unable to produce 2bar plenum conditions? Any help is much appreciated. Any more details required please ask.
Thankyou
James
Thankyou
James
RE: Compressor - Regulator - Plenum - Exit. Regulator not providing correct plenum pressure
Maybe your flow is more and hence your regulator is maxed out? Can you measure flow? Can you reduce the slot size?
Are you sure all the figures etc are all in absolute or gauge pressure? - Sorry if that sounds a bit simple, but you would be surprised by how many people get it wrong...
I have uploaded a diagram. The flow rate was calculated using the compressible mass flow equation at the nozzle exit (it is a convergent nozzle). Assuming the temperature is 293K I calculated density using the ideal gas law and then converted the mass flow rate into a volumetric flow rate. The pressure comes from a large compressor which supplies the building I work in. My part of the building has been regulated down to 6bar from 16. One suggestion was the use of a reservoir after the regulator with a control valve downstream of it. I would then pressurize the reservoir to 2bar and then open the control valve. Does this sound like it could solve the problem? If so, how?
James
Otherwise I suggest you post your calculation about the mass flow rate for others to pick over, noting that your comment "The slot is approximately the same area as the supply line pipe" doesn't seem to be correct. A 10mm tube has an internal area about 75mm2, your slot is 240mm2?? You could still be getting a lot more flow than you think / calculate, but I can't tell from current data.
Are you sure you're still getting 6 bar inlet when flowing?
I don't follow where the reservoir and control valve fit in relative to the plenum chamber and nozzle or whether your flow is a short term thing or a constant flow or what?
apologies for the error in the pipe size, I saw 10mm and assumed diameter as not many people quote radius.
I'm no expert on fluid flow like this, but if you are trying to equate a rectangular slot and using a circular nozzle formula I suspect that is where your errors might lie.
have understood that right?
what I was suggesting was that you actually post the calculations you have got, not just the formula.
