WCS problem on NX
WCS problem on NX
Hello everybody,
i use nx 9,
i have very big problem since i start using NX, sometimes i have to work on angled datums. And i have this. This is very big problem for diameter parts on drafting.
i can add a wcs like i want as you see on photo, but i can not use it on drafting etc,..
How can i solve it?
i use nx 9,
How can i solve it?
RE: WCS problem on NX
Are you trying to do drafting in the model space ?
It will never align with your modified WCS.
To do what you want, I made a video to show, see attached.
Anthony Galante
Senior Support Engineer
NX3 to NX9 with almost every MR (18versions) plus the NX10 Beta
Now i found a way to do it over solidworks :/
i export the file as parasolid.
i open it by solidworks, add a wcs , save as(by new coordinate axis). Then i import it to NX again.
For NX there must be something, i don't want to believe it's not exist.
There is only 1 WCS in an NX part file, it's your "mobile" co-ordinate system, like a 3D ruler. It is NOT a feature, and can't be copied into multiple positions.
But, once you've positioned the WCS, you can use it to create other things e.g.
- a datum co-ordinate system, which is a feature in the part navigator
- a saved custom view (view - set to WCS, then view - save-as) which is useful for drafting
and so on.
Hope that helps, Carl
www.jcb.com
NX 8.5 with TC 8.3
Format -> WCS -> Save
This copy of the WCS will show-up when you create your Drawing(s) while the one that's shown in Red/Blue/Green will not. Remember, if you're working in the Master Model mode you'll need to make sure that the copied WCS is included in your 'Model' Reference Set.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I have a feeling there is a better way to do it.
it was on an angled datum. Then the design changed and i put the parts to an another assembly.
Even when i export the file as a parasolid or stp file. it goes like this. Solidworks, inventor etc. open the file in this wcs.
Then in solidworks i can put a new wcs like i did in NX in video, i save the file as "with new wcs" . Everything becomes normal.
https://yadi.sk/i/5aXkus5Zd2Xyi
