Align Template Views (Creating a Template)
Hello guys, this is my first post :)
I am creating a Template(.drw) and im placing "Template views" in it, but i dont see where to click to aling the second Template view to the first one. for example the FRONT view with the TOP view, etc. In standard mode i will just use "projection" of the first view.
I checked the templates that come already bundled in the installation. If you use this templates your views will be aligned but when i open them directly ;as if i where to modify them, i can move the "template views" freely(not aligned). so i coulndt reverse engineer the method to do this.
i hope the question is clear.
Thanks.
Thanks.
RE: Align Template Views (Creating a Template)
couldnt edit the original post
The views will be aligned automatically when you use template when creating a drawing. In the template you must defined General view and other than Projected
It would make a lot more sense if you could pick an existing view and then on the RMB menu select insert projection view just like we do in normal drawing mode. Making sense is not one of the PTC user interface goals.
