Beginner... I put on a downward force and the results show oscillation.
Pretty much in the title.
I've put a downward force on a lip and in stead of just bending down the result shows the lip also springing back to the initial nd upwards above the initial state. Probably a single setting I need to adjust but unfortunately PATRAN questions are not very google friendly...
RE: Beginner... I put on a downward force and the results show oscillation.
Are you talking about the animation?
When you show the deformed shape you should have a bending in the downside.
I guess it is just about the animation settings
Seif Eddine Naffoussi, Stress Engineer
www.Innovamech.com
33650 Martillac – France
Yes it was just an animation setting. Thank you.
Hi Blomen,
Can you tell which settings you changed to get the correct animation?
Bis.
i found it
