XFLR5 Help
XFLR5 Help
I've got some co-ordinates that i want to put into XLFR5 however it doesn't seem to recognise the points apart from the first one. I realise that the shape isn't really an aerofoil and was wondering if this had anything to do with it? I am basically importing co-ordinates from a CAD model that was set up.
Many thanks for your help in advance!
RE: XFLR5 Help
RE: XFLR5 Help
RE: XFLR5 Help
The tool and target do not form a complete intersection.
RE: XFLR5 Help
RE: XFLR5 Help
RE: XFLR5 Help
OK I took a closer look... your line endings are encoded as a mix between \n and \r. It appears that XFLR5 only recognizes either \n or \n\r. To see them using notepad++ do View->show symbol->show end of line. The only reason my earlier changes worked is because it was re-saved with default windows line endings - so who knows if any of that stuff is necessary. For more info on line endings see http://en.wikipedia.org/wiki/Newline
You need to replace all your line endings with either \n or \n\r so in notepad++ do a find-replace, check the box "search mode extended", and replace \r with \r\n. Or maybe there is a setting in your software to save using windows line endings.
