Polyetheylene to Polycarbonate - Adhesive
I am working on a project for work and I am finding a real hard to time to find an adhesive that would stick Polyetheylene to Polycarbonate. I know there are some adhesives that are out in the market however they are flammable and therefore cannot be used in our manufacturing environment.
I need your expertise. Please advise.
Thank you for response in advance.
Steve
Steve
RE: Polyetheylene to Polycarbonate - Adhesive
Sorry for you but POLYETHYLENE, POLYPROPYLENE and PTFE have no adhesive, not at all. The only possibility is mechanical connection
Tom Quinn
Adherent Laboratories
www.adherentlabs.com
TomQuinn and CompositPro - I will give you more info on what I'm trying to do.
I'm trying to adhere a motion sensor lens to a polycarbonate plastic housing.
There is a small gap all the away around the sensor that needs to be filled. The housing has a "bowl" for the adhesive to sit in. The adhesive will be dispensed with an automated equipment.
The sensor itself is only good for +60°C so any adhesive must have an application temperature lower than that. The adhesive must also be clear when cured. This will eventually be build for production quantities - not sure exactly how many per hour but definitely not thousands/minute.
Thanks for the quick responses.
Steve
For your application a soft silicone rtv sealant should work fine.
I was thinking the same thing. The requirement of being clear with low application temperature limits the options.
Tom Quinn
I've used this before with reasonably good results on polyethylene tubing; it will stick with no surface prep, albeit with a somewhat low bond strength. It also sticks to polycarbonate well. It's cure time is temperature dependent, and will take a while in thicker applications.
http://www.amazon.com/Amazing-GOOP%C2%AE-Marine-Ca...
SceneryDriver
