Corrosion Coupons and Probes required ?
Our client has a non-corrosive fluid (NGL) pipeline. There is no chemical injection in the upstream of pipeline.
1) DO we still need corrosion probes/coupons on the pipeline when it goes underground and comes above ground ?
2) As I understand, coupons are generally used if there is any chemical injection in the stream ?
3) Also if the fluid is corrosive, no chemical injection, do we need corrosion coupons in that case ?
RE: Corrosion Coupons and Probes required ?
2) Coupons can be used for a number of reasons. Take a look at NACE Publication 3T199.
3) See 2)
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
