FBE VS HDPE Coating
FBE VS HDPE Coating
Assuming a condition where FBE and HDPE both can be applied for given temp., pressure, H2S, GOR, orientation, Service etc. How do we select between them ? Is it only the price and design life ?
Supposing a bulk header separator inlet and water/oil outlet piping. Which one of them would be preferred option ?
RE: FBE VS HDPE Coating
How you deal with welds, flanges and fitting is the big issue.
Which one? difficult to tell from your vague details, but if you've got gas or volatile components, check the diffusion rates.
For plant pipework this sort of thing is usually far too much bother / risk compared to using a material which doesn't need internal coating.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
