Combine curves
Combine curves
Hi all..good day..
I try to combine 2 or 3 curves to become 1 and will use that curve to create edge surface.I tried using combined/composite curves in Meshing Toolbox but the curve just change color and cannot be select as 1 curve.Anyone can solve it?
RE: Combine curves
Then go to the Meshing Toolbox use the combined/composite curves / add by point to merge curves.
Let me know if it works for you
Seif Eddine Naffoussi, Stress Engineer
www.Innovamech.com
33650 Martillac – France
