Governing Structural Code in 1923 in Portland Oregon
Anyone have any idea what the governing structural code would have been in Portland, Oregon, in 1923?
We have an old R/C building with concrete moment frames we have to analyze and want to implement the 10% rule if possible, but we need to determine what lateral and vertical design forces may have been used at that time.
I am old, but not that old...
Mike McCann, PE, SE (WA)
RE: Governing Structural Code in 1923 in Portland Oregon
However, knowing original design criteria should not be required to implement the 10% exceptions. It is just a % increase in demand or decrease in capacity. For instance, if a shear walls capacity is not reduced by 10% with a new opening when compared to the original construction is OK. Or, if the seismic mass/force contributing the load on the element in question is not increased by more than 10%, it is OK.
