Connect Cylinder Piston to Planetary gearmotor
First of all I would like to thank all helper. I am designing an automatic shotgun cleaner for personal usage. I am going to do a cylinder which will be tipped with a brush, connected to a cylinder piston to make front and back movement and then i am going to connect a planetary gear motor. So that the movement will be rotating and moving in and out of the barrel. My problem is that I don't know how to connect the piston with motor. Any help please.
Many Thanks,
acikkies
Many Thanks,
acikkies
RE: Connect Cylinder Piston to Planetary gearmotor
