Level Gauge - Reflex Type
Dear Experts,
I would like to know in case my fluid is corrosive (ex. LP Flare, Scrubber) can I use reflex type instead of transparent type?
What is the limitation when using reflex type?
Thanks!!!!
Thanks!!!!
RE: Level Gauge - Reflex Type
If your process fluid/operating conditions are compatible with tempered borosilicate, reflex is ok. If the sight glass is to be installed with a back light LED illuminator, a transparent must be used.
