Bridge Curve Disappears on Update
We recently upgraded to NX-9, and I've found that if I update something that breaks a bridge curve, when I fix the bridge curve, it disappears. Any later features that use the curve remain broken because I can't select the curve to fix it. When I right click on the feature it doesn't even give me a Show or Hide option, only Hide Parents. I've also tried using the Show All function, to no avail. Any help is appreciated!
RE: Bridge Curve Disappears on Update
If you could reproduce it in a simple example , where the bridge breaks, and upload, we could have a look.
Tomas
