Exception of parts sliced in a cross section view
Does anyone know how make 1 part not sliced in a section view. In the screenshot
yo can see a bolted connection and for clarity it'a better to have the bold non sliced.
Can that be done in NX (We could in Inventor)?
Thx in advance for helping me
Guusd
RE: Exception of parts sliced in a cross section view
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
It works but not always. When you select a body that you do not want to be sliced it
says 'SOLID' instead of the actuel p/n. I have to figure out why it doesn't work in all corcumstances
but at least there is a way it can be done.
The delay time for quick pick is adapteble in Preferences - Selection - Quickpick on delay, i have mine set on 0 sec, so the menu will appear instantly. Personal preferences, just play with it until you find a comfortable delay time for yourself.
Best regards,
Michaël.
Win 7 64 bit
Best regards,
Michaël.
Win 7 64 bit
Have you tried adding the 'non-section' Attribute to the Component?
If not, select the Component(s) that you wish to NOT section and add an Atrribute titled...
SECTION-COMPONENT
...and set the value to either YES or NO as desired.
This thread can be closed now.
gr
Guus
If you would like to have complete control over when and how fast the QuickPick option (i.e. the '...') appears, go to...
Preferences -> Selection...
...and in the 'QuickPick' section simply toggle the 'QuickPick on Delay' option OFF and hit OK.
Now when you place your cursor over an object the '...' will never appear until YOU hold down MB1 at least a half-second or so. This way it will ONLY come into action when YOU want it to, and you don't have to wait if you need it immediately, just hold down MB1.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
