Nx Nastran "Result in worng format"
I have a problem With my results were this is what iget. "Result File in wrong format" message.
This is the message in the *.f06 file:
*** USER FATAL MESSAGE 7555 (EMG)
FINITE ELEMENT QUALITY CHECKS FAILED.
USER ACTION: REVIEW THE QUALITY CHECK RESULTS AND ADJUST TOLERANCE VALUES IF DESIRED.
0FATAL ERROR
I have manually set the SORT1 option for the output request.
Do I have make changes to my mesh?
Can anyone help me find the problem?
/Håkan
0FATAL ERROR
/Håkan
RE: Nx Nastran "Result in worng format"
open your .dat file and check if GEOMCHECK exists. You could remove these lines or change the MSGTYPE = INFORM instead of FATAL.
Seif Eddine Naffoussi, Stress Engineer
www.Innovamech.com
33650 Martillac – France
