no-weld flange 2000 psig hydraulic 2" line
I need to make a field repair that entails digging up, cutting and re-flanging 2 inch sch 80 ASTM 106B (2000 psig hydraulic line) pipe.
The pipes are close together and the limited access area makes welding difficult.
The finished flange ends will have a masonry access box built around them and they will not be reburied.
Does anyone know of an off the shelf source for a slip-on clamp-on no-weld flange for this type of pipe and pressure?
Andy
RE: no-weld flange 2000 psig hydraulic 2" line
You could try looking at the post under yours - I've never used lokring, but it looks like what you're looking for.
Yep, Lokring is about the only option I can see for you. Good luck-
