How do you correctly call out coaxial holes that need to be inline so that a bolt could go through
I'm attaching a sketch of a situation that I'm encountering where I need to make sure that the co-axial holes on a clevis remain inline after the stamping is complete. The holes are done at the last stations and I need to be able to locate both holes correctly so that I will be able to get a correct length on the assembly equipment. I don't believe the datum scheme lends itself well to control and gage R&R but this is all I have to work with.
Please let me know if I'm calling out the datums correctly and the datums are set to what I'm trying to achieve and to let me know if the composite position tolerance I have there is called out correctly and will locate this hole at a distance away from the cylinder and inline with each other.
Thanks for everyone's help.
RE: How do you correctly call out coaxial holes that need to be inline so that a bolt could go through
How close do the fits in the holes have to be? Bending and welding are not accurate processes. Your specification looks reasonable to me, although the position tolerances should have diameter symbols.
You need either to open up your holes and tolerance so that bending and welding will create conforming parts. If you need the thing to be accurate, you will have to apply the tolerances, and accept that the fabricator will machine after welding.
JHG
1. Like drawoh said, the diameter symbols should precede tolerance values in both segments.
2. Datum feature referenced in the lower segment is not a subset of datum features referenced in the upper segment.
Additionally nothing controls location of these hole in x direction. Basic 230.7 dimension suggests that the end face is intended to serve as datum feature for locating the pattern in x direction, but at the moment the print does not say that.
As for datum feature C, perhaps it would be reasonable to consider entire width 74.3 between clevises as datum feature instead of picking one of the faces. Is there any particular reason for that?
Is this part rigid or subject to free state variation?
The hole location only needs to be accurate to position tolerance of 1.5mm but from hole to hole they must be lie within 0.5mm to each other so that the customer can fit the bolt through both holes without any additional force.
The part will be subject to free state variation I believe. It is assembled into a strut assembly. There will be assembly variation as well as variations on all edges of the clevis as it isn't controlled other then general notes.
The cylindrical part of this part is formed and is subject to variation due to the process. The end face is toleranced as a profile of 1.5mm but was not included in the drawing by my error. It is not a datum.
To correctly call out the location of the holes, what would need to be done? If the face of that cylinder is datum A and then surface of the leg is datum C, would that allow the callout that I had to be valid?
If I wanted to call-out positions from the centerline of the cylinder to locate the holes, would I need to add an extra D datum to the face of the cylindrical portion and called out the top part of the composite feature frame to A and D and the bottom feature control frame to C, would that allow for the control I'm looking for?
Thanks.
pmarc, can you give more detail to this statement? Are you saying that C is not a subset of A & C? Or are you saying that the datum in the lower segment must be held to a feature that IS the upper segment (meaning that the bottom segment is to be a datum feature [hole] that is held to the upper segment {hole])?
By subset I meant that lower segment of the composite callout can specify A or in some cases A|C or in some cases no datum feature references. Anything else is illegal.
Thanks for the information. So that means none of the call-outs I mentioned would work as well. So would this be acceptable and allow me to have control over the location of the hole to the datum scheme and secondarily with the hole to hole dimension. The new call out I would use is
TP D 1.5 to A C D and the secondary feature frame of D 0.5 A C
Second question is if I just went with
TP D 1.5 to A D and the secondary feature frame of D 0.5 A would that give me the position of the circles to be parallel but off in the x direction?
Thanks for any help.
eeyew, there is an example in Y14.5-2009 that is nearly identical to your situation. See figure 7-45. In it, they use a three segment composite tolerance. Not sure if this does what you're looking for, but it's so similar, I thought I'd bring it to your attention.
Thanks for the response. I do not have a copy of the latest Y14.5 spec so can you please explain to me what it says in that figure? Thanks a lot for your help.
Page 140 for the figure.
Should they be posting that? I am pretty sure it is copyrighted.
JHG
If I have somehow broken some Eng-Tips posting rules, I apologize and will understand if an admin edits or deletes my post above.
http://en.jlu.edu.cn/University/SubpageInfoAction_...
Jilin University
Jilin University, founded in 1946, located in Changchun, the capital city of Jilin Province, is a key national comprehensive university, under the direct jurisdiction of the Chinese Ministry of Education, supported by Project 211 and Project 985. In 2000, the former Jilin University merged with four other universities, namely former Jilin University of Technology, former Norman Bethune Medical University, former Changchun University of Science and Technology, and former Changchun College of Posts and Communications. In 2004, the former University of Military Logistics also became part of Jilin University.
Thanks for the help. It helped me out a lot. I've attached another sketch and am hoping that this makes sense. It seems like there's a circular reference in there that may make it invalid so I want to make sure that if that's not possible, I'll have to find an independent way of doing so.
The cylinder will be a wrapped cylinder and therefore the surface that I'm trying to make a datum will vary and I'm trying to limit that variation. I care about that surface so I can't just label it a datum with general notes. Please review the sketch and let me know what you think.
Tunalover
Unless it's a sloppy fit into the next assembly, it should not use MMC for the cylinder.
The in-line hole callout is a width dimension, so there's no location tolerance closer or farther from the flat on the left. Use a radial leader to indicate the diameter of the in-line holes.
Thanks for your comments. It makes sense to me that there's still a single degree of freedom available. So I've attached a new markup adding another datum to the surface profile that should set that last degree of freedom. I changed the call-outs to reflect this. Can you please let me know if my call-outs are legal and it's doing what I think it's doing.
In the die, the legs are bent into it's final location via a few stations, the holes are then pierced at the same time after the legs are in their final location.
Thanks for your help.
I would assume also, that each hole is held to the tolerance in the FCF independently, correct?
What I'm getting at is that CF doesn't offer any refinement or special inline alignment between the two holes, right? It would be the same as calling out each hole separately.
Not trying to be argumentative, just trying to make sure I understand how CF would work on holes like this.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
In other words, is the tolerance diameter projected across the entire length of the ceneterline of the holes, or is each hole measured independently?
Datum features of the part should be selected based on mating relationship of that part with other components in assembly. When you look at datum features you have selected, do you think these are the features that play the most significant role in locating/orienting this part in the assembly? That is the first question. The second question is: what is the precedence of datum features? Is surface A really a better candidate for primary datum feature than diameter B? Another question, if the part is subject to free state variation (which seems to be the case here), perhaps it would be reasonable to inspect it in a restrained condition (a condition that would simulate forces/deflections happening in real assembly)? As for B referenced at MMC/MMB, does that mean the dia. 50.6+/-2 cylinder is mated with a hole of dia. 52.6 min?
You are correct that your previous pictures showed circular referencing of datum features. The problem with your latest sketch is that datum features A, B and C are not controlled relative to each other at all. If A is trully a primary datum feature, B secondary and C tertiary, the datum feature B should be controlled for perpendicularity relative to A, and the datum feature C for profile relative to A|B. As long as there is no relationship between datum features defined on the drawing, the drawing is incomplete.
Regarding some other comments made in this discussion:
- Using a radial leader to indicate the diameter of in-line holes will not introduce anything new to the definition. Both methods - the one currently shown in the sketch, and the method with a leader - are legal ways to define the diameter of in-line holes. What is missing is the diameter symbol in front of both tolerance values in composite position FCF.
- <CF> modifier will turn two independent holes to a single feature of size. This means that hole-to-hole relationship will be controlled by the MMC envelope of dia. 18.30 that neither of the holes will be allowed to violate (this virtual envelope is common for both holes). Current sketch allows axes of both holes to be offset 0.6 max relative to each other, as defined by lower segment of composite FCF. This offset will be limited to 0.1 max, if <CF> modifier is used.
Tunalover
Please also note that use of CF symbol is only allowed per the ASME Y14.5-2009 standard where it was introduced. If using the 1994 (or prior) standard, other methods will need to be used to define the two surfaces as a single feature.
Usually there are 2-3 ways to *correctly* --functionally- define a product.
Not 50 ways and “probably” not a single way!
Just my opinion.
I found on Tec-Ease *ONE* way to define *A* clevis.
The shown clevis may not work/functions in the same way as the OP’s clevis.
Hope this helps more than confuse
eeyew,
You can also read the above thread/link. 4 cases of clevis are discussed (at least in the begining of the thread)
