Need to use a geometry without a contraint
Hello! I am trying to create a model consisting in two geometrys (image attached). The first one is a fixed sheet. The second one it´s a pin. This pin is part of a bigger geometry that is trying to move in Z direction. The pin is supossed to constraint that displacement by it's Contact interaction with the sheet. Mi question: i do not want to put a constraint to the pin, i would like to put just the load and the only constraint i want is due to de Contact interaction. is it posible? it seems Femap is asking me for more constraints when i run the analysis and read the error window. thank you in advance.
I am sorry about my poor english!
RE: Need to use a geometry without a contraint
Thank you very much
