NX DRAFTING ASSOCIATIVITY
Anyone having trouble re-associating notes with leaders after a geometry update?
RE: NX DRAFTING ASSOCIATIVITY
Edit -> annotation -> origin, pick the balloon/note and press OK. This should reset the balloon/note origin to be set at the current position without any associations.
You didn't mention the version of NX you are using. The menu location should work for most recent versions with the possible exception of NX 9.
www.nxjournaling.com
For me it can be quickest just to delete the existing leader and add a new one.
It is possible that the note became unassociated because it was (unknowingly) linked to either the view itself or an entity in the view that changed with the geometry change.
edit (pull down on NX7.5) -> annotation -> origin -> unchaeck "associative"
