Surface element normal velocity
Hi all,
I am performing an acoustic analysis using the Boundary Element Method.
The procedure needed is that after performing a direct frequency analysis, I need from abaqus
to give me the normal component of velocity for single element. In other words, I want the velocity
of every surface element to be analyzed to its own local coordinate system. Is that possible?
Thank you
Thank you
