Spring definition in Ansys
Hello dear experts,
I need to subject to a static structural analysis a metal/rubber spring (a steel spring dressed in rubber). Until now, for the metal components of rubber/metal bushes I used the structural steel from Ansys library. For this spring, more exactly for the metal part of the spring (which is an actual steel spring) I need to define the steel spring material and I'm not sure if I can find a suitable material in Ansys library. Can someone guide me in defining a spring steel in Ansys?
Thank You!
Thank You!
RE: Spring definition in Ansys
Rick Fischer
Principal Engineer
Argonne National Laboratory
