Mechanical Shaft Ventilation Requirements
Where in the ICC or NFPA does it talk about ventilating mechanical shafts? Does this only apply to high rise buildings because of stack effect? I know about specific ventilation requirements for elevator shafts, but not mechanical shafts.
RE: Mechanical Shaft Ventilation Requirements
What did you mean by mechanical shaft
A mechanical shaft filled with ductwork, plumbing and mechanical water pipes.
No ventilating requirements. Wherever the ducts penetrate the 2-hour wall to the occupied spaces, a fire/smoke damper might be required (US) and a duct smoke within 5' of said device.
