Stick vs Wire Welding
I have a project with several CJP welds.
Within the construction documents, I have called for E70 electrodes to be used in a stick welding application.
The erector has come back to this office and asked if he can use a wire fed welding procedure using NR-232 Lincoln Electric wire.
Have you guys run into this before? I am not familiar with the NR-232 wire, but in comparing the E70 to the NR-232 data, it looks like the Charpy V Notch data is much higher for the stick weld.
Is this a substation you guys allow.....going from stick welding to wire fed welding? I don't have a feel for the capacity difference nor the cracking potential difference. I have called Lincoln to get their input on this issue, but have not heard back yet.
RE: Stick vs Wire Welding
