scaling up of base shear
Dear all ,
i have a 19 floors building and i am using Etabs for seismic analysis,i am starting a g/R (R=4) as minimum scale factor for response spectrum case ,but when comparing the base shear between static and dynamic the ratio V(static)/Vdynamic =6>R,thus the scale factor for spectral case is (g/R)*(ratio) that give a value greater than g.what shall i do in this case.
thanks in advance .
thanks in advance .
RE: scaling up of base shear
