Do the Hollo-Bolts connections require seal
Hello!
When bolting to the hollow section using Hollo-Bolts (bolt hole drilled in the wall of hollow section as shown on attached image) is it good practice to use mastics to seal joint to prevent uncontrolled corrosion inside of hollow section?
Thank you for your answers.
RE: Do the Hollo-Bolts connections require seal
No attached image visible.
Treat is like any HSS member; Either seal it or paint/coat the ID if used outdoors. The bolts are 'almost' self-sealing; the problem is the raw' tubesteel exposed to atmosphere.
