Symbolic Thread
Symbolic Thread
In NX 8.5.1.3 I have two plates in 1 assembly.
When I subtract a false body in 1 plate and add a symbolic thread, it shows as a dashed line.
When I do this in the other plate, the symbolic thread shows as a solid line.
Is there a setting in the part file to change to get the dashed line?
RE: Symbolic Thread
RE: Symbolic Thread
RE: Symbolic Thread
If you do not use the hole chart, it may be in the Preferences, Visualization under the Line tab. You might be able to control how large the dashes are. Though this is just my guess as I have not checked to see if this would fix that particular problem.
Also, if you have edges behind edges turned on in the view settings, it might cause the dashed lines to look solid if there are two of them (one in front of the other) in the view.
