Software for calculation of Insulation of Cryogenic tanks
Hello Everybody,
We have a cryogenic tank which is housing BUTENE at -6.4 degree celsius. We have various insulation layers for the tank along with following technical data for the tank.
1. Tank diameter (inside) = 36.00 m
2. Tank height = 10.80 m
3. Liquid level = 10.50 m
4. Storage material = Butene
5. Design Temp (°C) = -24 °C
6. Operating Temp (°C) = -6.4 °C
7. Liquid Spec. Gravity = 0.6011
8. Net working capacity = 5434 m3
http://files.engineering.com/getfile.aspx?folder=9...
Would really appreciate if somebody can suggest me some good software to do a detailed THERMAL analysis for this cryogenic tank in order to understand its thermal parameters and how much each of the insulation material affects the tank's overall insulation.
Any guidance / help would be extremely appreciated.
RE: Software for calculation of Insulation of Cryogenic tanks
Anyway, I'm not familiar with the kind of software you're looking for but you might try the "Heat Transfer & Thermodynamics engineering" forum here:
http://www.eng-tips.com/threadminder.cfm?pid=391
Thanks for your response. You're right normally cryogenics are below -150 C but here still as the Butene is in liquid form and also maybe client wants to call it so its called as cryogenic. I am looking for a software which can take inputs as parameters related to various materials for insulation and then in the end give us an OUTPUT in the form of insulation value of overall structure. We have some issues with the perlite blocks as the ring beam of main tank structure so are looking to replace them. Need detailed design before replacing them.
Regards.
As for software, something this complex would require a finite element analysis (FEA) tool, see http://en.wikipedia.org/wiki/List_of_finite_elemen...
You could try to do that with other general purpose tools like Mathcad or Matlab, possibly even Excel.
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
Thanks for replying back. I have attached some more details regarding insulation of the tank as well as the related codes. All the relevant information is as in this link.
http://padlet.com/meesamalinaqvi/i9jzooldg3rq
Kindly review the same and recommend good strategy / software / solution to move forward. We're really stuck for the time being. Any help is appreciated.
Regards.
