Catia Macro: Get Parent of drawing view object
I have created a drawing view of an assembly. In that view, I select an edge or point-Is it possible to get the name of its parent part. Or is it possible to get the point's actual 3D coordinates.
RE: Catia Macro: Get Parent of drawing view object
Quick code using the view...
CODE -->
Sub Draw()
    Dim oDrawing As DrawingDocument
    Set oDrawing = CATIA.ActiveDocument
    Dim oSheets As DrawingSheets
    Set oSheets = oDrawing.Sheets
    Dim oSheet As DrawingSheet
    Set oSheet = oSheets.Item(1)
    Dim oView As DrawingView
    Set oView = oSheet.Views.Item(3)
    oView.Activate
  Set ProductName = oView.GenerativeBehavior.Document.Parent
  MsgBox ProductName.Name
    End Sub
______
Alex ,
if views are link with sub element of product:
CODE --> VBA
Sub Draw()
    Dim genLinks As Collection
    For i = 1 To oSheet.Views.Count - 2  'not checking background and main view
        Set oView = oSheet.Views.Item(i + 2)
        Set genLinks = ViewGenerativeLinks(oView)
        If genLinks.Count = 0 Then
            MsgBox (oView.Name & ": Isolated view")
        Else
            For U = 1 To genLinks.Count
                MsgBox (oView.Name & " link " & U & ": " & genLinks.Item(U).Name)
            Next U
        End If
    Next i
End Sub
Function ViewGenerativeLinks(oDrawingView As DrawingView) As Collection
    Dim result As New Collection
    On Error Resume Next
    Set oLink = oDrawingView.GenerativeLinks.FirstLink
    If Err.Number = 0 Then
        result.Add oLink
    End If
    While Err.Number = 0
        Set oLink = oDrawingView.GenerativeLinks.NextLink
            result.Add oLink
        End If
    Wend
    If result Is Not Empty Then
        Set ViewGenerativeLinks = result
    Else: Set ViewGenerativeLinks = Empty
    End If
End Function
Eric N.
I've been searching fot this issue
Quote (man2007)
Quote (Google)
.Restriction Explanation
Generative geometry object (genItem) is not
exposed by automation API, that's why it is not
possible to select it.
.By-Pass
Generative Geometry is only accessible by CAA
C++ interface
Please correct me if i am wrong.
______
Alex ,
Thanks AlexLozoya and itsmyjob for your replies.
Yes, I was looking for "genItem", so that I can get the parent of the "genItem", which I feel, is not available in VBA library.
