Macro for creating Axis Systems
Hi, can anyone help me with creating a macro who will create axis systems from sketch. Exmlpe, i ll create sketch with points and than call macro to make Axis System, thx
RE: Macro for creating Axis Systems
I need macro who will create let say 30 axis systems from sketch who have 30 points(befor macro i ll create plane and sketch on it, and i need that z axis is parenculan on that plane) thats all. For example i need to asemble 30 parts, and i m using that created axis.
If you want to assemble some parts is good enough to know their position, is not necessary to create axis systems. Just try to record this action in CATIA and you will see. Try also to record action after inserting the part in product (in a specific point or by default), moving to another position and you will understand more.
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
It is for me, i have a lot of reasons why i m using axis systems, thx anyway
ub CATMain()
Dim partDocument1 As PartDocument
Set partDocument1 = CATIA.ActiveDocument
Dim part1 As Part
Set part1 = partDocument1.Part
Dim axisSystems1 As AxisSystems
Set axisSystems1 = part1.AxisSystems
Dim axisSystem1 As AxisSystem
Set axisSystem1 = axisSystems1.Add()
axisSystem1.OriginType = catAxisSystemOriginByPoint
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Item("Geometrical Set.1")
Dim sketches1 As Sketches
Set sketches1 = hybridBody1.HybridSketches
Dim sketch1 As Sketch
Set sketch1 = sketches1.Item("Sketch.1")
Dim reference1 As Reference
Set reference1 = part1.CreateReferenceFromObject(sketch1)
axisSystem1.OriginPoint = reference1
axisSystem1.XAxisType = catAxisSystemAxisByCoordinates
Dim arrayOfVariantOfDouble1(2)
arrayOfVariantOfDouble1(0) = 1#
arrayOfVariantOfDouble1(1) = 0#
arrayOfVariantOfDouble1(2) = 0#
Set axisSystem1Variant = axisSystem1
axisSystem1Variant.PutXAxis arrayOfVariantOfDouble1
axisSystem1.YAxisType = catAxisSystemAxisByCoordinates
Dim arrayOfVariantOfDouble2(2)
arrayOfVariantOfDouble2(0) = 0#
arrayOfVariantOfDouble2(1) = 1#
arrayOfVariantOfDouble2(2) = 0#
axisSystem1Variant.PutYAxis arrayOfVariantOfDouble2
axisSystem1.ZAxisType = catAxisSystemAxisByCoordinates
Dim arrayOfVariantOfDouble3(2)
arrayOfVariantOfDouble3(0) = 0#
arrayOfVariantOfDouble3(1) = 0#
arrayOfVariantOfDouble3(2) = 1#
axisSystem1Variant.PutZAxis arrayOfVariantOfDouble3
part1.UpdateObject axisSystem1
axisSystem1.IsCurrent = True
part1.Update
Dim settingControllers1 As SettingControllers
Set settingControllers1 = CATIA.SettingControllers
Dim visualizationSettingAtt1 As VisualizationSettingAtt
Set visualizationSettingAtt1 = settingControllers1.Item("CATVizVisualizationSettingCtrl")
visualizationSettingAtt1.SaveRepository
End Sub
Your recorded macro is a good starting point. What if you don't have sketch.1 ? Or how do you loop thru points ? Bellow is an example done by me for a Spanish forum (insert an Euler Axis System in a specific point).
CODE --> CATScript
Language="VBSCRIPT"
Sub CATMain()
Dim partDocument1 As Document
Dim part1 As Part
 axisSystem1.Name = "MyAxis"
axisSystem1.Type = catAxisSystemEulerAngles
Dim parameters1 As Parameters
Set parameters1 = part1.Parameters
str1 = CATIA.ActiveWindow.Name & "\MyAxis\EulerAngle1"
Dim angle1 As Parameter
Set angle1 = parameters1.Item(str1)
angle1.Value = 45.000000
Dim parameters2 As Parameters
Set parameters2 = part1.Parameters
str2 = CATIA.ActiveWindow.Name & "\MyAxis\EulerAngle2"
Dim angle2 As Parameter
Set angle2 = parameters2.Item(str2)
angle2.Value = 90.000000
Dim parameters3 As Parameters
Set parameters3 = part1.Parameters
str3 = CATIA.ActiveWindow.Name & "\MyAxis\EulerAngle3"
Dim angle3 As Parameter
Set angle3 = parameters3.Item(str3)
angle3.Value = 20.000000
Dim hybridShapes1 As HybridShapes
Set hybridShapes1 = hybridBody1.HybridShapes
Dim hybridShapePointCoord1 As HybridShape
Set hybridShapePointCoord1 = hybridShapes1.Item("Point.1")
Set reference1 = part1.CreateReferenceFromObject(hybridShapePointCoord1)
axisSystem1.XAxisType = catAxisSystemAxisSameDirection
axisSystem1.YAxisType = catAxisSystemAxisSameDirection
axisSystem1.ZAxisType = catAxisSystemAxisSameDirection
part1.Update
End Sub
Fernando
I will always use sketch, i have the sistem of work, for every gropus of parts i create sketch and with sketch i manipulate in xy plane, and sketch is created on plane so i can manipulate with z, when i create Axis System i use only one constraint, and that is constraint betwen that AS and AS in specific part.
did you try to use Assembly user pattern if you want to duplicate some part based on a points in a sketch?
Eric N.
I dont have manipulation who i want, and its not point on that, point its on macro.
yes, with powercopy, no with macro ...
hi, i think i am making Progress, i have code here but it wont work any help? i have a lot of preoblems with CreateReferenceFromBRepName
Language="VBSCRIPT"
Sub CATMain()
Set Document = CATIA.ActiveDocument
Set oPart = Document.Part
Set axisSystems1 = oPart.AxisSystems
Set oBody = oPart.Bodies.Item("PartBody")
Set oSketch = oBody.Sketches.Item("Sketch.1")
Set geometricElements1 = oSketch.GeometricElements
For i = 1 To geometricElements1.Count
Set axisSystemi = axisSystems1.Add()
axisSystemi.OriginType = catAxisSystemOriginByPoint
Set referencei = oPart.CreateReferenceFromBRepName("BorderFVertex:(BEdge:(Brp:(Sketch.1;i);None:(Limits1:();Limits2:();+1);Cf11:());WithPermanentBody;WithoutBuildError;WithSelectingFeatureSupport;MFBRepVersion_CXR15)", sketch1)
axisSystemi.OriginPoint = referencei
axisSystemi.XAxisType = catAxisSystemAxisByCoordinates
arrayOfVariantOfDouble1(0) = 1.000000
arrayOfVariantOfDouble1(1) = 0.000000
arrayOfVariantOfDouble1(2) = 0.000000
axisSystemi.PutXAxis arrayOfVariantOfDouble1
axisSystemi.YAxisType = catAxisSystemAxisByCoordinates
arrayOfVariantOfDouble2(0) = 0.000000
arrayOfVariantOfDouble2(1) = 1.000000
arrayOfVariantOfDouble2(2) = 0.000000
axisSystemi.PutYAxis arrayOfVariantOfDouble2
axisSystemi.ZAxisType = catAxisSystemAxisByCoordinates
arrayOfVariantOfDouble3(0) = 0.000000
arrayOfVariantOfDouble3(1) = 0.000000
arrayOfVariantOfDouble3(2) = 1.000000
axisSystemi.PutZAxis arrayOfVariantOfDouble3
oPart.UpdateObject axisSystemi
axisSystemi.IsCurrent = False
oPart.Update
Next
End Sub
