Nastran SOL700 problem
I run Nastran SOL700 analysis - bottle.bdf.
Link
But I still get this warning:
Error executing subprogram. Reason (errno) = 2.
No such file or directory
Please ensure your P3_TRANS.INI or site_setup file correctly points to the solver executable or that you have correctly set the proper environment variables to do the same.
How to fix it?
How to set Patran Configuration Utility?
Thank you.
Link
How to fix it?
Thank you.
RE: Nastran SOL700 problem
You can also create a .bdf of your analysis (Method / Analysis Deck) and then drop it on the Nastran icon (desktop). but first right click on this icon and set the start directory to the one containing your project...
Seif Eddine Naffoussi, Stress Engineer
www.Innovamech.com
33650 Martillac – France
Nastran solves it, there's no problem,
but how to submit SOL 700 analysis from Patran?
hezhj2000, thanks for help.
I set enviroment variable NASTRAN_VERSION as is shown below and now it is OK.
