User alias and space bar key
I am new to Catia. I worked in Solid works and Autocad. When I add the shortcut keys through user alias in Catia, I am facing a problem in entering the 'enter' key. For example, I have assigned 'F' for 'fit all' command. if I want this shortcut, I need to press F button first and go to right for 'enter' button. But, in AutoCAD, if we press the 'space bar', it is fine to execute the command. If it is possible, I can assign more than 20 shortcuts by simply typing the "letter+space" in one hand while I am using mouse in another hand. So, please give idea that
1.if it is possible to assign the space bar as enter key
or
2.instead of using 'enter' key in key board, if it is possible to middle button of mouse for enter.
So that, I will use the left hand for letter typing and right hand for enter button.
Suresh
or
Suresh
RE: User alias and space bar key
I hope this helps.
PS sorry for the excessive use of '''s
Rob Stupplebeen
www.optimaldevice.com
https://sites.google.com/site/robertkstupplebeen/
Thanks for the reply. I have a doubt in the accelerator key setting.
In the accelerator key, we can use (CTRL, SHIFT & ALT)+any letter. But, I have a query in 'other' pop up which has enormous keys.
I used 'space+F' key for fit all short cut as a trial basis. But, when I type space itself, the drawing or model got start to fit.
please clarify me that the key available in other folder are only to be assigned or '+ letter' to be used
Suresh
