Forged vs. Rolled tube sheet
Does the code allow using tube sheet made from hot rolled plate instead of forged one?
RE: Forged vs. Rolled tube sheet
For what - a heat exchanger under ASME Section VIII, Div 1 or firetube boiler under Section I or a condenser?
ASME Section VISION Div.1
Yes.
The choice is up to the designer based on service conditions, mechanical properties required and thickness.
