Wind Load on 3-Wall Metal Bldg
Hi all,
I was designing an open pavilion structure (monoslope roof) for uplift using ASCE 7 Fig 27.4-4, only to find it has been decided that the building will have wall panels on the sides and back. To me this just looks like a parachute for wind, and the uplift and overturning forces should increase by more than simply adding a wind pressure meant for an external wall. If anyone knows how to get the loads for this (specifically wind loads for the wind direction blowing into the building), then your help or recommendations would be appreciated. I attached a picture in case there's any confusion as to the type of building I'm talking about.
labeattie
labeattie
RE: Wind Load on 3-Wall Metal Bldg
Mike McCann, PE, SE (WA)
http://files.engineering.com/getfile.aspx?folder=5...
When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.
-R. Buckminster Fuller
Can you please attach the coversheet of the docyument you stated.
I would like to purchase it but I don't what is the exact title of the document, where I can buy it directly if it cannot be shared.
I appreciate your assistance.
http://www.mbmamanual.com/products/13-2012-metal-b...
Thank you very much, I appreciate it.
I found it. Again thank you so much. (I am a new engineer.)
Have a good Thanks giving.
Regards.
