Interference joint...
I deal with analysis of the interference joint between shaft and sleeve. I want to simulate the effect of surface roughness and method of assembly (shrink or bush) for the joint load.
This analysis I’d like to divide into two steps:
1. At first step i want to simulate the interference joint between shaft and sleeve.
2. At second step i want to simulate the value of torque moment which can shaft and sleeve interference joint carry. I want to use in this case as the boundary condition the simulation results from first step.
I need help because I have some problems. I simulated process of the interference. I received the results, and now I would like to use this results to second part of the analysis. I don't know how to use obtained results as the boundary condition i the second part of analysis.
How can I use results from first stage of analysis in the second step?
How can I model different surface roughness (now I use connection property)?
Maybe someone will have a different idea how can I simulated this process?
Thanks and let me know if you need any additional information. I appreciate your help.
Andrzej
Andrzej
RE: Interference joint...
so you need to estimate the normal force on the interface due to the interference (should be able toget that from your model).
then assume a CoF
and so calculate the friction on the interface
and so calculate the torque it can sustain.
