DC Motor Help
DC Motor Help
DC Motor Help
I was wondering if anyone could help me figure out where to find specs of a motor with very little markings. The 12v DC motor comes out of a 5 Oceans 4" in-line blower. I cannot find any specs on it and the company has not returned my emails or calls. The only marks on the motor say "S-60933E157". I've searched everywhere I can think with no results. So I turn to you, any help would be greatly appreciated. Thank you.
RE: DC Motor Help
Is it a replacement you need? Does the original motor work? Or do you need the data for some other purpose?
There are different approaches depending on what the answer is.
Gunnar Englund
www.gke.org
RE: DC Motor Help
The original motor works great. For my R&D application it is the best fan I have found, so I am trying to find the same motor but as a AC unit instead of DC. If nothing else, a very close match. So I was hoping that the "S-60933E157" would tell someone (more knowledgable than myself) some information about the motor or at least where to find the specs.
RE: DC Motor Help
Quote (Ballantyne888)
There can be a world of difference between an AC motor and a DC motor. It is not just as easy as selecting the "AC" option. You may be better off trying a few AC motors to see how they work.
RE: DC Motor Help
You could of course use the DC motor you like, fed from AC via a bridge rectifier and optional big smoothing capacitor.
RE: DC Motor Help
@7anoter4 yes, that is the blower. @logbook ok I will start trying that. I wasn't sure if it would be a better starting place to have the HP and RPM of the motor. Thanks everyone for your help.
