Composite gear: MINLON (Nylon 6) - RUBER
Hi to everyone,
I am interested in making a composite mechanical gear for a water pump, comprising of two parts. The first one will be a polymer and the second one rubber which will be vulcanized (in the presence of S) on top of it at 160 degrees Celsius. I have the following questions about the selection of the polymer:
1) Is MINLON (mineral reinforced Nylon 6) a proper selection for the polymer in terms of mechanical characteristics? If not, any other suggestions?
2) The adhesion between MINLON and the rubber part is a crucial characteristic in our application. Will this composite system (polymer-rubber) be able to handle torsional stresses?
3) During the vulcanization process at 160 degrees Celsius, will the MINLON part remain stable?
Thanks in advance
Thanks in advance
