How to eliminate static and magneticism from a metal (stainless steel)
I am neither a Magnetic engineer, electric engineer or anything related hence me asking a question here and also giving those of you who are a reason to excuse my ignorance, of what may be a stupid question (or at least stupid to some since many of us believe there is no such thing as a stupid question.)
I have tools, tweezers to be exact) which are supposed to be stainless steel but are either not stainless steel or of very pool quality. Since a cheap magnet (the type you use to stick paper to a board) easily sticks to the tweezers shows they are not anti-magnetic. Is there anything I could do to make them anti-magnetic? more precisely I want to make it anti-static? Or minimize such qualities? thank you
RE: How to eliminate static and magneticism from a metal (stainless steel)
Once made, steel cannot be made "anti-magnetic," since that property is inherent in the alloy metals used.
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
I was aware of the 300 and 400, I did after all do some research
I did have a feeling that this could not be done but wanted to make sure. But yes, I do have an anti-static strip; and by you answering this actually helped in a different way as well since it saved me from asking another questions which would be: is an anti-static wrist band good enough when using metal tools?
If you don't mind I would like to ask another question if I may, while we're on the subject--2 actually.
I think metal tools or other metal things can be made anti-static, correct? and this would be by adding some sort of coating.
The 2nd question is: what defines a ''good'' anti-static tool? Yes, one could buy one from a reputable company and increase the chances of it being so but besides this is there an other way of knowing. I mean I could always rub myself against a carpet and see if static occurs (if this makes any sense)but is there anything else?
Thanks again and it''s OK if you don't answer since at this point it's purely for curiosity, personal educational purposes.
As for indicators, static field meters are relatively inexpensive, and you should have one if you are this concerned, as you should be, about ESD. Do you have an ESD training regimen at work? If not, you should.
Note that in extremely low humidity environments, having an ESD smock is a must, because your clothes are the biggest source of ESD, and since the clothing is non-conductive, a wrist strap would not prevent an ESD discharge from your clothing to a critical component, were you to reach over that component and accidentally touch it with your clothing. Our company's ESD regimen includes conductive work surfaces, conductive containers/bags, ESD straps, and conductive smocks.
TTFN
You've answered all I want to know so need to go no further. But just for fun let me respond to some things you wrote in reply.
All the info I asked for is for personal information. I like to educate myself in all things of interest . It has nothing to do with work. I'm in the arts (writing/teaching etc.) but the sciences are on top of the list of interests and having many friends in the engineering fields (Aeronautics, Robotics, Electronic and a few others)or having worked with them in some capacity or other has maintained my interest.
When you said, "static field meters are relatively inexpensive'' I assumed you meant for work purposes, therefore inexpensive from that POV. or else to me inexpensive would have to mean under $10. (now you know where I' coming from
Once again I thank you for your time. I am indeed grateful.
