Turn Part Family Member in normal Part by Journal
we often get Assemblies from suppliers that need to be imported into Teamcenter. These Assemblies contain parts from Part Families. I know that it is possible to convert Part Family members into normal Parts during the import process. But I have to add additional attributes to all parts of the assembly before I start the Import (e.g. OS_Part_Name). Is there a way to switch a Part Family part into a normal part by using a journal because Part Family members can not be saved with their changes.
This is my journal to add the needed attribute to all parts in one directory. But I need help to remove the Part Family information.
CODE --> vb
Option Strict Off
Imports System
Imports NXOpen
Imports System.Diagnostics
Module NXJournal
Sub Main
' Overall StopWatch
Dim stopWatch as StopWatch = new StopWatch()
Dim value As TimeSpan
Dim totalTime As String
' Individual Part StopWatch
Dim partWatch as StopWatch = new StopWatch()
Dim partTime As TimeSpan
Dim totalPartTime As String
' User Entry
Dim path As String
path = "C:\Temp\test_refile\"
Dim logFileName As String
logFileName = "C:\Temp\test_refile\xxxx.txt"
stopWatch.Start()
Dim theSession As Session = Session.GetSession()
Dim loadedPart As String
Dim loadParts() As String
' Read Directory
Dim directory As New IO.DirectoryInfo(path)
Dim directoryFiles As IO.FileInfo() = directory.GetFiles()
Dim fileNames As IO.FileInfo
Dim basePart1 As BasePart
Dim partLoadStatus1 As PartLoadStatus
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim markId1 As Session.UndoMarkId
Dim partSaveStatus1 As PartSaveStatus
Dim OS_FileName As String = Nothing
Dim write_at As String = "OS_File_Name"
For Each fileNames In directoryFiles
  Dim read_at As String = ""
  ' Start the StopWatch
  partWatch.Start()
  '   Menu: File->Open...
  basePart1 = theSession.Parts.OpenBaseDisplay(path + fileNames.Name, partLoadStatus1)
  partLoadStatus1.Dispose()
  markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Enter Gateway")
  workPart = theSession.Parts.Work
  workPart.ModelingViews.WorkView.Fit()
  '   Write OS_FileName Attribute
		Try
			OS_FileName = fileNames.Name.Remove(fileNames.Name.Length - 4, 4)
            workPart.SetAttribute(write_at, OS_FileName)
        Catch ex As Exception
            MsgBox(write_at & " : " & OS_FileName & ex.Message)
        End Try
  '   Menu: File->Save
  partSaveStatus1 = workPart.Save(BasePart.SaveComponents.False, BasePart.CloseAfterSave.False)
  partSaveStatus1.Dispose()
  '   Read OS_FileName Attribute
		Try
            read_at = workPart.GetStringAttribute(write_at)
        End Try
  '   Menu: File->Close->All Parts
  theSession.Parts.CloseAll(BasePart.CloseModified.CloseModified, Nothing)
  workPart = Nothing
  displayPart = Nothing
  partSaveStatus1 = Nothing
  basePart1 = Nothing
  partWatch.Stop()
  partTime = partWatch.Elapsed
  totalPartTime = string.Format("{0:00}:{1:00}:{2:00}.{3:00}", partTime.Hours, partTime.Minutes, partTime.Seconds, partTime.Milliseconds/10)
  My.Computer.FileSystem.WriteAllText (logFileName, "Loaded: " + path + fileNames.Name + Environment.NewLine, True)
  My.Computer.FileSystem.WriteAllText (logFileName, "OS_FileName: " + read_at  + Environment.NewLine, True)
  My.Computer.FileSystem.WriteAllText (logFileName, "Elapse Time: " + totalPartTime + Environment.NewLine + Environment.NewLine, True)
Next
'   Menu: Tools->Journal->Stop
stopWatch.Stop()
value = stopWatch.Elapsed
totalTime = string.Format("{0:00}:{1:00}:{2:00}.{3:00}", value.Hours, value.Minutes, value.Seconds, value.Milliseconds/10)
My.Computer.FileSystem.WriteAllText (logFileName, Environment.NewLine , true)
My.Computer.FileSystem.WriteAllText (logFileName, "Total Load Time: " + totalTime, true)
End Sub
End Module
Thanks in advance
Carsten
RE: Turn Part Family Member in normal Part by Journal
If you perform a Save-As on the family member, the newly created part will not be associated to the family table.
www.nxjournaling.com
That works perfect. It can be so easy. bigsmile
Thank you.
